valve seal and valve stem oil seal
nickmx3
Post by nickmx3 »
I would like to know are these the same parts just referred to by different names. or are they two separate parts.
Also what do you guys think about felpro parts, thanks guys
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
Re: valve seal and valve stem oil seal
Post by wytbishop »
The valve rides up and down in the VALVE GUIDE. The VALVE FACE contacts the VALVE SEAT which is pressed into the head and carefully machined to match the valve face to seal the combustion chamber. The VALVE STEM SEAL or simply the VALVE SEAL has a metal body which fits over the valve guide and a rubber (actually Butyl or Viton usually) lip which seals against the VALVE STEM to prevent oil from leaking down the stem onto the valve face and being burnt.
There is no other "seal" associated with the valve assembly.
Return to “Forced Induction”
