Resetting ECU
Resetting ECU
Ok, which fuse is it you pull to reset the ECU???<P>I know how to do it with disconnecting the battery, but it's easier to pull a fuse than it is to disconnect the battery. <P>Can anyone advise ??
Re: Resetting ECU
I think you mean the main fuse, it's under the hood and in the fuseblock like a little b----. Just disconnect the battery or you'll bust of the fuse(trust me)
'95 Blue Creek Mica RS<BR>Vermont
- Shady469
Re: Resetting ECU
why would you want to reset the ECU??<BR>(I don't know too much about the ECU's)
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Re: Resetting ECU
Yeah, I know what you mean by the main fuse being a b----......i tried to pull it and didn't get it out (so I didn't try any harder) Almost looks as though there is a bolt holding it in.... <P>I'm resetting mine because of my intake and because my car was doing wierd things during idle after long runs. Trying to see if this will fix it. Probably not, but it's worth a shot
- Custommx3
- Site Administrator
Re: Resetting ECU
Unplug the battery for 30 mins..<BR>that should do it. Should only a few mins, but just to be safe, leave it unplugged a while.
