how much can you boost on stock injectors and a front mount intercooler.... im thinking 5ive pounds should be good what do you guys think....
also still looking for ideas on how to route my inter cooler piping still waiting on my radiator so... still got a while before i get it on the track again....
							how much boost can stock take.?
- PWRD_BY_HKS
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- solo_ryder
Re: how much boost can stock take.?
With stock injectors you would be lucky if you weren't maxing out the duty cycle at 4 psi or less, it's not a good idea at all to boost on blue tops. If you are smart you would get a set of red tops and that would solve the issue for up to 8-9psi.
As for the FMIC, figure something out, it is not that hard. There isnt a whole whack load of boosted v6 mx3's around so pics aren't magically going to show up. Just route the passenger side pipe under the rad area near the tow hook and the drivers side you cut a hole under the headlight and run through were a CAI would normally go.
				hgallegos915
rudy you love risking your poor engine dont you? LOL
At 5 psi the wideband shows the injectors topping out at around 4 k rpms and i would backfire ugly(lean) BOOM
Just buy the millenias man, dont skimp out on fuel now. Get yourself a freaking wideband :/ why are you against widebands?!
-hec
