Well it has been raining for about a day and a half and I have noticed the floor board behind the driver seat is soaked I have no idea where it could be leaking into the car from my guess would be the sunroof but it looks good.
Any one else have this problem and or know how I can fix it thanks
Water Leaking into back seat floor board?
mudvaynedg
Re: Water Leaking into back seat floor board?
Try replacing the rubber surrounding that goes around the drivers side glass outer railing. I replaced mine with some universal surrounding from Autozone, that has a sticky adhesive bottom. My OEM surrounding was bad.... but once I put the new surrounding on, I haven't had a problem with leaks in almost 5 years.
Hope this helps mudvaynedg.
If you fall, then get back up........Luck favors the prepared
- Ryan
I have a similar problem....
In the hatch, one day, it was wet underneath the carpet... on the drivers side right at the back in that little inlet thing. I just soaked it up with a rag, but Idk where it came from
i had the same problem! except it turns out someone just got into my car and left the door open and stole my radio on a rainy night!
Never be afraid to try...amateurs built the ark, professionals built the titanic.
