For those who aren't paying attention, here's the speculation: Acetone increases milage.
I understand forum members jman271 and fowljesse are currently using acetone. I also understand Tunes has also tested the effectiveness of acetone. If you have any questions, direct them to a forum member that is currently using them
Acetone, also known as dimethylketone and 2-propanone. . It's the simplest ketone molecule: CH 3 COCH 3.
Flashpoint temperature:
Acetone: -18 C
Gasoline: -43 C
Auto-ignition temperature:
Acetone:465°C / 869°F
Gasoline:232°C / 495°F
Recommended amount to use in fuel: use in a ratio of about 5000:1 to 3000:1. Suggested is no more than 3oz per 10gal.Added to the fuel tank in tiny amounts, acetone aids in the vaporization of the gasoline or diesel, increasing fuel efficiency, engine longevity, and performance -- as well as reducing hydrocarbon emissions.
http://peswiki.com/index.php/Directory: ... l_Additive" onclick="window.open(this.href);return false;
http://pesn.com/2005/03/17/6900069_Acetone/" onclick="window.open(this.href);return false;
A snippet from the GM service manual:Wiki wrote: Automotive fuel additive
Some automotive enthusiasts add acetone at around 1 part in 500 to their fuel, following claims of dramatic improvement in fuel economy and engine life.[3] This practice is controversial as the body of systematic testing shows that acetone has no measurable effect or may in fact reduce engine life by adversely affecting fuel system parts.[4][5][6] Debates on this subject and the perrenial claims of a "Big Oil" cover-up intensified when the practice was addressed on the popular American TV show MythBusters in 2006, and shown to have negative effect in the televised fuel economy test.[7].
WHAT NOT TO DO: Engine and Fuel Additives, Alternate Fuels, and "Miracle" Products
Various unproven products to improve vehicle fuel economy have been reported ranging from magnets that align molecules to chemical combustion improvers.
Most products claiming to provide benefits are based on unsubstantiated claims. Those that do present "scientific" results generally either have too little supporting data to be conclusive, have not conducted experiments in a controlled fashion, or cannot be substantiated by anyone else but the product's manufacturer.
The U.S. Federal Trade Commission summarizes results for products tested by the federal government at FTC Bureau of Consumer Protection. A review of the list shows that the majority did not work, and for those that showed some effect, the benefit was too small to be cost effective.
Harmful Ideas That May Damage Your Vehicle and Increase Emissions
Notice: Never put Kerosene or Diesel Fuel in your Gasoline Engine vehicle. This may result in inconsistent performance and permanent damage to your vehicle that is not covered by your New Vehicle Warranty.
Notice: Never use acetone, ketones, or methanol additives in your vehicle. Some of these solvents may damage or corrode your fuel system. They are also very damaging to the painted surfaces of the vehicle if spilled.
Chemicals that are normally used as solvents also should not be used. These include acetone, ketones, and methanol. These solvents can be incompatible with your vehicles rubber or sealing components, and may dissolve the vehicle’s paint finish. In the case of methanol, corrosion of metal parts in the fuel system also may occur.
GM/ASE Certified Service Consultant
