instant power cut....no spark
well driving the mazda home the other day the power instantly cut out, revs dropped to zero, and it would not start, it would turn over but would not start. i have done the hei module/blaster 2 coil mod and it worked great for over a year, and now all of a sudden i cant get a spark. i have only tested 1 plug so far and no spark but im going to test a few more, and also going to check the resistance of the blaster coil, anything else you think could be the problem? also how would you know if the hei module crapped out? also i ran codes and i am getting 2,4,15,16,24,29, which most of em im used to getting since the klze swap.
You know the world is going crazy when the best rapper is a White guy, the best golfer is a black guy, The Swiss hold the America's Cup, France is accusing the US of arrogance, and Germany doesn't want to go to war
- tehbrookzorz
Re: instant power cut....no spark
Some parts stores have a machine that can test your ignition module. Try calling around. No codes?
Cody
![Image](http://i.imgur.com/Q0Vh17N.jpg)
