DELETED
93BlackMX3
DELETED
Post by 93BlackMX3 »
DELETED
solo_ryder
Re: Fixing Up A GS Lip
Post by solo_ryder »
Fiberglass it together on the back of the lip, you can get kits at hardware stores
93BlackMX3
DELETED
DELETED
JoshVK
Post by JoshVK »
i used tin and rivets.. but up to you..
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
Kirk95gs
Post by Kirk95gs »
I f/g mine. both sides. however I hit a racoon a couple weeks later and smashed it. :cry: But I will be fixing once again sometime.
Check out this LINK on how I did it.
Return to “Appearance”
