So before I put my tranny in with the clutch I got now, I took some pics of it to see if you guys could tell me if its worth putting back in, or I should just get a new one. So here it is and thanks for the advice ahead of time
Look below for links
Do I need a new clutch
Re: Do I need a new clutch
can you link pic someplace else? i get a "you have to log in" message..
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
I would as long as you have it apart. It doesn't look too bad but i dont like the rubber bushings.... the napa replacement has springs instead and if you get the kit for $125.00 (just bought one this week) you get a new throwout bearing, disc, pressure plate, pilot bearing (the one in the center of the flywheel), and the alignment tool which centers the disc while you tighten the pressure plate. I also got a new flywheel at napa for $42.00 as opposed to $25 for resurfacing.
92 MX-3 GS 1.8, looking for ZE.
forgot to mention that i noticed the rust coated flywheel in the background of one of the pics, you definately want that thing clean like a morror before you put it together and resurfacing is 25-30 dollars as opposed to a brand new napa one for only 15 dollars more. if you get the kit and flywheel for about $175.00 your clutch will be good for 175000 miles of normal driving. thats the mileage in mine and the clutch just went out.
Thanks for the advice, Ill probably get a new flywheel, until I can afford the fidanza one, but I will probably just buy a newer better oem one, I dont want stock but I dont want expensive staged clutch. So Ill look around but that kit is wicked cheap so thanks for the advice
And for new links here you go hope this works
http://a508.ac-images.myspacecdn.com/im ... 374343.jpg" onclick="window.open(this.href);return false;
http://a397.ac-images.myspacecdn.com/im ... 1e2774.jpg" onclick="window.open(this.href);return false;
http://a936.ac-images.myspacecdn.com/im ... 4284ff.jpg" onclick="window.open(this.href);return false;
http://a645.ac-images.myspacecdn.com/im ... d8c5c4.jpg" onclick="window.open(this.href);return false;
http://a860.ac-images.myspacecdn.com/im ... 3b2b43.jpg" onclick="window.open(this.href);return false;
http://a316.ac-images.myspacecdn.com/im ... ac95ab.jpg" onclick="window.open(this.href);return false;
http://a661.ac-images.myspacecdn.com/im ... 34b934.jpg" onclick="window.open(this.href);return false;
http://a192.ac-images.myspacecdn.com/im ... 1470cf.jpg" onclick="window.open(this.href);return false;
