VRIS compatibility between intakes
Posted: March 28th, 2008, 5:24 pm
by nightfire
Hey guys. Sorry if this has been asked before; I searched and didn't find anything.
Are the VRIS solenoids compatible between intakes? Can I take them from my straight-neck KLZE intake and use them on a curved neck millenia intake?
Re: VRIS compatibility between intakes
Posted: March 28th, 2008, 6:06 pm
by JoshVK
Im curious as well... someone has to know.
(sorry if you take this as hijacking) but to add to your question.
i still don't know what VRIS stands for/means. if someone could fill me in on that as well thanks...
Posted: March 28th, 2008, 6:41 pm
by Kirk95gs
VIRS = Variable Resonance Induction System
Check this out
http://www.geocities.com/mikey9t6/car_uvwxyz_vris.htm
basicaly it helps hold high torque across the RPM range.
I used one solenoid off my k8 for my millenia motor. you might need a diffrent bracket for some manifolds *however dont quote me on that* Someone on the board will tell you.
Posted: March 30th, 2008, 2:37 am
by hgallegos915
Solenoids are the same, also heres a tip
that solenoid that goes to the for? that can also work for vris.. i think.. lol Its confirmed that the lock that locks the cris shaft fits lol I used it today.
