Oil Pan Gasket, or Not??
Posted: March 26th, 2008, 12:51 am
Does the oil pan use a gasket, or not (1994 1.6 stick)?
I've heard both ways, that manufacture'rs spec is to use one, and I've also heard that manufacturer's spec is just to use RTV.
Some shops sell the gasket some don't. Which is it?
Thanks!
Also, is it best to drop the exhaust a bit from where it sits under the pan to get to those bolts, or do you guys recommend leaving the exhaust and the bolts are still doable with it there?
Thanks!
