Does the oil pan use a gasket, or not (1994 1.6 stick)?
I've heard both ways, that manufacture'rs spec is to use one, and I've also heard that manufacturer's spec is just to use RTV.
Some shops sell the gasket some don't. Which is it?
Thanks!
Also, is it best to drop the exhaust a bit from where it sits under the pan to get to those bolts, or do you guys recommend leaving the exhaust and the bolts are still doable with it there?
Oil Pan Gasket, or Not??
- Limegreen mx-3
Re: Oil Pan Gasket, or Not??
on all 1.6 sohc and dohc oil pain i remove none use it even the 1.8 dohc oil pan..
u used silicone gasket maker to seal it..
on my dohc they came with end seals and a tube of rtv
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
I did mine recently and there was no gasket for the lower part of the oil pan. That was the steel part of the pan. I think it's a 2 part pan because when I was looking for the parts, I needed to replace my pan, I got 2 different prices on oil pan gaskets. One was a tube of RTV the other was the end seals and a tube of RTV.
But, my car is automatic, so, I don't know for sure...
![Welder :welder:](./images/smilies/welder.gif)
