Cheap Ebay HID Kit
Cheap Ebay HID Kit
Hey was just wondering who out there has cheap ebay HID kits. I was trying to figure out if I should buy those are go with more pricier ones. The cheapest one I found were these:
http://cgi.ebay.com/ebaymotors/92-04-MA ... enameZWDVW
I heard from a friend that they have problems not working all the time and he had to move it around occasionally for it to light up. Anyone with any experience with them? Pics would be nice too.
94 mx3 rs
92 mx3 gs curved neck klze SOLD
Re: Cheap Ebay HID Kit
Try contacting lowridah313 off these boards. I have pics of an HID kit he had on his old mx that he bought off ebay. He might be able to give you the link to the ebay seller's HID kits. From what he told me they were good quality and affordable.
Friendship is like pissing your pants: Everyone can see it, but only you can feel its true warmth.
- mitmaks
wouldnt you have overheating problems and melt your stock wiring with this kit?
looks just like my kit only I got one with HI/LO. Make sure you get an auction with 9004 bulb though! you don't want to put an H4 bulb in the 9004 housing or vice versa!
FYI 8k is gonna be really blue... go with 6k or lower but that's just my opinion though.
- mitmaks
how do you like your kit? was it worth it? any other feedback?Mooneggs wrote:looks just like my kit only I got one with HI/LO. Make sure you get an auction with 9004 bulb though! you don't want to put an H4 bulb in the 9004 housing or vice versa!
wow really no one else besides mooneggs?
94 mx3 rs
I got the cheap 9004 Hi/lo kit for $100 - it worked great for more than 3 months - then i drove through a flash flood and now one of the bulbs is acting up a little - its not exactly easy or cheap to get replacement bulbs - the seller i bought it from is not responding to emails.
are the bulbs specific to the kit? i didnt really look into that.shameem wrote:I got the cheap 9004 Hi/lo kit for $100 - it worked great for more than 3 months - then i drove through a flash flood and now one of the bulbs is acting up a little - its not exactly easy or cheap to get replacement bulbs - the seller i bought it from is not responding to emails.
94 mx3 rs
Any of you that have baught HID Kits... Are you happy with the spread pattern?
My HID's shine in the trees, up high... But yet on the road it's not angled out far enough.
--- K8 was my gateway drug.
My lighting pattern is not optimal - but i discovered that if i stopped cleaning the headlights then it gets dispersed more evenly on the road. Also i heard that if you get the bulbs that have a metallic cap tip thing for the high/low control then you will have really weird pattern like up on trees and not enough on road. If you get a telescoping kit you probably will be ok.
the ballasts seem to be pretty generic so the plugs coming out of the ballast works for almost every bulb type because the connectors are the same coming from the bulbshameem wrote:I got the cheap 9004 Hi/lo kit for $100 - it worked great for more than 3 months - then i drove through a flash flood and now one of the bulbs is acting up a little - its not exactly easy or cheap to get replacement bulbs - the seller i bought it from is not responding to emails.
Yes but all the replacement bulbs i see on ebay are for single beam - not telescoping ..... There are a few telescoping replacement bulbs - but they cost like $80+ which is bad considering that i got the whole kit for a little more than that.....
Telescoping? ... What is this?
- 94mx3precidia
wow this is the first ive heard of hid conversion kits that are relatively cheap. there was one question that i read that wasnt answered and id like to know. "wouldnt you have overheating problems and melt your stock wiring with this kit?" other than that it seems like an okay kit but you get what you pay for.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
No you won't melt your wiring, or your headlight shell.
But note: ... Anything is possible.. lol
The knock off HID kits are cheap... and good. If I wasnt so unhappy with the pattern on our lens i'd love mine. Which, I'd like them even more if I didnt accidently get 1000K... straight blue.. lol
