I did the HEI mod, and I have an external coil as well. I have and can verify that I have VERY strong spark. I know i am getting fuel, I know my pump is operating properly, I have my back seat ripped out and have tested it throughly. I have no oil in my coolant or vice versa. I was driving it around today trying to figure out as to why it was running like crap.
I was about to go pick up a can of seafoam when the car flat out died, and has since refused to start. I cant figure out what the deal is, timing is on the mark that was set before it died... Also before anyone chimes in, I have brand new wires, new platinum plugs and a new rotor button, oh and a new cap.
Now, I have pulled codes from the ECU I have codes 08 and 10. IAT sensor and VAF.... Now I dont know about the VAF but Toyota AFM's (they do the same job as a MAF essentially) trigger the fuel pump when you crank the engine over. My fuel pump kicks on and off exactly when it should, so my question is, could it be throwing a code because when I came and looked at the car the previous owners were trying to crank it without the VAF plugged in? I have cleared the codes, but I dont know if the ECU can re-record them without starting and driving the car, which I cannot do.
I can also verify that the VAF is plugged in, it is on securely and that connection cant get any tighter. I am going to the junkyard tomorrow and I am going to look for a Probe GT or Mx-6 VAF since I am fairly certain that they dont have ANY Mx-3's there. If the VAF isnt bad I am going to go through the injectors, which I can only assume are also the same on the Mx-6 and Probe.
SORRY! I didnt mean to type quite so much, but I want to cover everything so you guys know my situation. I am a newbie I have never owned an Mx-3 before, can you tell?
I guess I just want to know if the VAF triggers fuel the pump, and if so could it still trigger the pump and cause a no start situation? Or am I probably looking at injectors?
Thanks! Chris
