I need to replace my distributor for my 92 v6 1.8l , but have only been able to find ones from a 93 V6 1.8l and a 94 V6 1.86 (TOT number is 57071.) I have heard there are various sizes etc would either of these two fit in my 92.
Thanks in advance Hutch
Distributor compatibility
- onlytrueromeo
Re: Distributor compatibility
Instead of replacing the distributor, maybe look into doing the HEI mod? its in the V6 FAQ.
And, I might be wrong, but I believe that the V6's have the same disty throughout - the I4's change between the 92-93 and 94+
- solo_ryder
OBD1 uses the same disty, so a 92 93 and some 94s will work. Get the 93 or go with a 93 probe or mx6 one, those will work too
