ive got a major problem when im at idle my car is running at 2100 rpm why is it running so high is my maf going out or is it a timing problem? i really need your help guys im not going to give up my baby ive had her for 14 years and shes never let me down and im not giving up on her
1.6L SOHC
HIGH RPMS AT IDLE
koketsu-mx3
- TREVO123
Re: HIGH RPMS AT IDLE
check for vaccum leaks, Run some injector cleaner they could be dirty and makin them have to work harder.. Run for codes in the dianostic box with w paper clip.. 10 and GRN and count the flashed. Slow Flash = 10 and quick ones = 1 and then come back on here and search for the code..
- Custommx3
- Site Administrator
Stick with the same topic.
http://www.mx-3.com/phpBB3/viewtopic.php?f=50&t=62816" onclick="window.open(this.href);return false;
