HIGH RPM AT IDLE??????????
koketsu-mx3
i have a 93 mx-3 1.6l SOHC for about 2 months the rpm has steadily risen and currently it idles @ 2100rpms the throttle screw is turned down i took it to a mechanic and he says its reading +51 degrees is that BS or is it possible i need suggestions to find out what might be wrong...maybe the maf? im not sure help me out guys
- Custommx3
- Site Administrator
Re: HIGH RPM AT IDLE??????????
probably need to reset your TPS.
thats more than just turning a screw
There may be a how-to somewhere, but I dont have the procedure for the SOHC.
It requires jumping GND to TEN in diag mode and using a gap gauge between the stop screw on the v6. maybe similar for the SOHC. maybe others can chime in that have done it.
koketsu-mx3
is that the screw that keeps the cable guide from going all the way backits rolled all the way back.
how do i know if the tps is bad?
