Winter BPT Project
JeremyP
Winter BPT Project
Post by JeremyP »
have a 94 mx-3 with a bp thats developed a tick...i was thinkin about doin a motor in the winter and was wondering if theres a guide. would it be easier to build it myself or just buy it?..possible looking for a donor motor if anyones got one too....and tips really would help
thanks guys
TREVO123
Post by TREVO123 »
Build it up! Bp is better then BPT!! Build ur bp for boost!
Limegreen mx-3
Post by Limegreen mx-3 »
[quote="TREVO123"]Build it up! Bp is better then BPT!! Build ur bp for boost![/quote]
hey man a comment like that can get ya bashed by other BPT owners.
since ya not being boosted know what i mean.
I believe what ur saying but still i won't even go there.
Post by Josh »
I will ^^^^
Stock motor for stock motor an N/A BP with stock BPT Turbo will make more than the BPT. Proven fact
Stock BPT will dyno at around 155WHP and an N/A BP with BPT turbo gear will dyno about 175WHP.
for newbs, the N/A head has alot bigger intake and exhaust ports as well as it has higher comp pistons. result about 20+ WHP over the BPT. The N/A rods do hold out to about 28PSI too. so dont give me any of that BPT rod crap...lol
Limegreen mx-3
Josh wrote:I will ^^^^
Hey i believe the BP n/a is a hell of alot better than the BPT.
but most other think differenly..
gald to see im not the only one that thinks the BPT is so great.
more like over rated..
dave0r
Post by dave0r »
na the BP N/A just has higher compression pistons and different cams
so if you turbo it..it'll make more power right away...
BPT motor is 90% the same as BP anways, its just got different pistons and cams, and head inlet ports shaped for low down torque that are more suited to boost all round
but yes...turbo a stock BP and you get more power than a stock BPT
SOLD 1991 Mazda Astina GT, BPT,161 WkW @ 9psi, & 102wkw N/A built motor with LSD
1996 ST205 Toyota Celica GT4, big brakes, massive power
worked KL-ZE 220whp in the build, possibly for a 323 or MX3/Eunos
Volones
Post by Volones »
OK, I'm a little confused now. Does the BP (turbo'd), or the BPT make more torque at low RPMs? Dyno slips would be nice (or a link to one), but some kind of numbers would be fine too. I'd really like to see how much torque is available between 2k - 4k RPM.
natural born honda killer
Post by natural born honda killer »
this is of my gtr motor at about 13 psi or so.
jeremy cline
95 MX-3 RS
The only BPT GTR MX-3 in Texas!!!
man iraq sucks!!!
