TPS Output voltage
ModMX3 - (Carmaster2005)
TPS Output voltage
Anyone know what the voltage is supposed to be on the green/white wire at full throttle on the TPS ? Becaust the 5 volt power wire i get 4.97 volts and the output wire green/white at full throttle i get 3.80 volts is this low or high ? Thanks
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
