Need Help Fast (no start)
- lowridah313
So I just swap the wifes auto trans in her 94 GS. I get everything buttoned back up, and now the car wont start. It has power(battery), it has fuel, but it wont turn over, as in the starter doesnt crank. So I swapped starters today, still no luck. If anyone has any input I'd like to hear it, Ill try anything to fix it.
-Tom-
-Tom-
Representin' the THRE3:TH1RT3EN
'02 Nissan Xterra SE, atx, 4x4, 32's
'92 Geo Tracker atx, 4x4
Feedback http://mx-3.com/phpBB3/viewtopic.php?f= ... 54&start=0" onclick="window.open(this.href);return false;
Bochek
you swaped trans? did you swap to a manual or another automatic...
if manual... you have to trick the ecu to think its in part or neutural....
if automatic.... make sure you have thoes wires hooked up
hgallegos915
He swapped auto with auto.
did you check the starter? Is it connected? what about the neutral start switch?(auto transmission)
-hec
- mx3autozam
Tom..you never called me? i woulda helped you out
but pretty much make sure all grounds are hooked up(is there power for everything else lights and all) all sensors are hooked up including neutral switch. Check it over.
how good are the connections to the starter? is there little trigger wire taht goes on the starter connected and secured?
93 Mazda MX3 KLZE Turbo
blackops032
- BANNED Member
- lowridah313
Checked the starter its fine. I have power to it. All plugs and wires are hooked up, gonna jump the park/neutral switch to see if its bad. Thanks everyone.
- lowridah313
I just wanna thank everyone for your help in solving my problem. It turns out that the starter was not self grounding on the transmission itself. So I ran a wire with a ring terminal on either end from one of the starter mount bolts to the chassis ground(same as the battery) she fired up like a champ! So yet again thanks to all(especialy Tunes67)
- mx3autozam
- lowridah313
Personally John I'm not conserned about that anymore, as weird as it is. I'm just happy it runs and drives. We figure that there had to have been something inbetween the starter and the trans stopping it from grounding. You think i would have seen something when I put the trans in, or when I changed out the starter. bah ohwell problem solved.
