First of all I haven't driven this car in a few months. It's a '92 GS. So I replaced my battery, it popped real good when I installed the 2nd terminal the first time. I went to start the car and nothing, no power at all. So I took off the battery terminals and hooked them back up, just to make sure I had a good connection, then there was no pop or spark or anything the 2nd time - still no power obviously. Checked the fuses under the dash and the blue "ENGINE" fuse was popped. I replaced it and it busted again. The other blue fuse on the outside of the fusebox was busted, so I replaced it, and then replaced the blue "ENGINE" fuse and they both held. Still no power. So I check the main fuse box and the "MAIN FUSE" is blown. I went to replace it and as SOON as i touched the connectors to it, it blew.
Does this sound like a short? Maybe a relay?
I am moving in a few days and I really need to get the car running. Any help would be greatly appreciated. Thank you all very much.
-Mike
Main Fuse keeps blowing>
- mx3autozam
blackops032
- BANNED Member
