Short Throw
Posted: July 29th, 2007, 9:13 am
by MazdaNoob123
Quick question...
Will a MX6 B&M short shifter fit the Mx-3?
i only ask cause i have the chance to buy a mx6 shifter for $15
Posted: July 29th, 2007, 10:49 am
by 1992blazeredgs
More than likely it should, same tranny so the way the linkage connects should be the same. Linkage will probably be longer than mx3, but still connect the same. For $15 bucks i would try it, and if it doesnt work i bet you could make it work.
Nate
Posted: July 29th, 2007, 3:11 pm
by JoshVK
for 15 bucks you cant go wrong... and if it does please post up... ill look for mx6 shot throw.. as mx6 parts are often easier to find...
Posted: July 30th, 2007, 12:28 am
by PATDIESEL
I'm almost 100% that they do. Look at B&M's website for the part number of the MX-6 and MX-3 versions. If the part numbers are the same then the shifter is the same.
