size of rear speakers
what size are the rear speakers? thanks
Hard to say some people have different sized ones, as i have 6.5 inch all the way around. Easiest way to find out is to take them out, a couple of bolts and its out...
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- Tropical Emerald 1993
- PATDIESEL
5.25, but with a trim ring that will hardly fit any other speaker and is almost impossible to remove without tearing up. I would suggest a 6.5" speaker and making your own trim rings for attaching it to the cover. You can make the rings from a simple piece of MDF or good plywood. I use MDF b/c it is harder and thus rattles less than other types of plywood.
- Tunes67
There are adapter rings out there for this.. to go from the 5.25 to 6.5 inch. When I had my Kickers installed w/ the new panasonic head unit into my RS, the Car Stereo shop had the adapters in stock.. didnt charge me for them either. Maybe check with your local car stereo shop.
Tunes67
Tunes67
