Honda engines...
Juans_93_MX3
Honda engines...
Post by Juans_93_MX3 »
Why is it that I usually hear people say, "yeah some Honda engines only weigh like 20 pounds."
Is that true?
How much do our engine weigh? What about transmissions?
I just find it hard to believe a engine can weigh so little
2008 Mazda 3
1993 MX3 GS
JWMX3
Post by JWMX3 »
I guess those people are talking about the 4hp honda lawnmower engines :P
Hoodzy
Post by Hoodzy »
yah some do... wheed wacker engines
1995 Creek Mica Blue GS
mitmaks
Post by mitmaks »
"it's not how much it weighs, it's how you weedeat with it"
But does it blend?
2RotorsNaDream
Post by 2RotorsNaDream »
How do you even believe these people?!?! A 20lb motor would never withstand the heat that a car would require to move. You gotta think about the crazy things that people tell you and ask yourself if it makes sense. A Honda engine is like any other engine, it probably weighs 250+ lbs., I've lifted them before with friends.
tehbrookzorz
Post by tehbrookzorz »
I think I read somewhere that somebody had removed his engine and transmission and he figured his car was 600 lbs lighter. Our engines are relatively light for their size. It's not like we have iron blocks.
Cody
mx3autozam
Post by mx3autozam »
whats up with all the honda bashing? Honda negines are pretty light and small and make nice power. go look into a Type R motor.
93 Mazda MX3 KLZE Turbo
hgallegos915
Post by hgallegos915 »
type r motor does not weigh 20 lbs. its a good engine.
-hec
tehbrookzorz
There hasn't been any bashing, yet.
"Go home Honda boy! Come back when you have enough hp to make it off the line!"
Cody
cyclonekid78
Post by cyclonekid78 »
HONDA SUCKS. :twisted:
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
ElectricEnergy
Post by ElectricEnergy »
"My lug nuts require more torque than your engine makes!"
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
Hoodzy
Post by Hoodzy »
"I see your engine is a 1.4L where my mountain dew has 2L."
"Racing a civic is like winning the special olympics.. if you win your still retarded"
hgallegos915
I accidentally raced a civic today at the track.. it turned out to have the sohc engine :( it was such a dissapointed that I didnt even floor it at the end,, i just coasted down aww. :( I got my behind handed by a gtp tho :D lol
-hec
Franko
Post by Franko »
The honda block is made of aluminum so it is extremely light. That is most likely what those people are talking about. I lifted my buddys b18 out of his trunk when it was stripped down just to the bare block and it would blow your mind how light it is. You can lift it up with 2 fingers no problem but if you go to lift one of our iron engine blocks up it is quite heavy. I was bringing my bp block into the house and after a bit of walking it was getting pretty hard after a minute or so. You could easily carry 2 honda blocks, one in each hand.
