Calling all people with Fidinza Flywheels
Juans_93_MX3
In your guys opinion, is the flywheel worth the $200-$300 or whatever amount it costs?
I know those flywheels are made to free up power, were you guys satisfied with the gains?
I understand a light flywheel will give very quick revs but are not really that good for daily driving. Whats your guys opinion on that?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- XxantwawnxX
I can tell u its drives great as a daily.
hgallegos915
At the drag strip it makes your third gear really pull.
when me and my friend rudy used to race (hes faster dunno ahy hah) hes got some nice drag radials. He gets a pull on me at launch but then i pull on him and stay even (back then) with him until the finish line. As a daily driver is awesome. Highly recommended.
-hec
- mr1in6billion
Re: Calling all people with Fidinza Flywheels
YES - well worth the investment! I also love the fact that when my Stage 2 clutchmasters decided to break apart and destroy the surface of it I was able to buy a replacement surface (it's some type of special material)... been working great for the last 100k miles!Juans_93_MX3 wrote:In your guys opinion, is the flywheel worth the $200-$300 or whatever amount it costs?
mx3biotch
Ya Dude, I have a Fidanza Flywheel and a Fidanza Clutch and its amazing, learned how to drive a stick on it so that was interesting but it revs nice and its my daily driver as well and I love it.
94 GS, J-spec KLZE, KL31 ECU, KL31 Cams, Fidanza Lightweight Flywheel/Clutch, Custom CAI with K&N, NGK Plugs/Wires, Phenolic Thermoblock Spacers, Custom Magnaflow 2" Exhaust, Custom Titanium Paint, Carbon Fiber Altezzas, 16" Miata Wheels, Crossed Drilled Rotors w/Silver Calipers, Tint, Ground Control/Tockiko Suspension, Ground Control Rear Strut Bar, 6 Point Roll Cage, Corbeau CR2 Seats, Sparco 3 Point Harness, MOMO steering wheel/drifting e-brake/shifter, mx3 door sills/pedals, Carbon Fiber dash inserts, Silver vinyl door insterts, JBL power series 6.5" front components/4x6 rear components, 4 channel amp, infinity 10" self powered sub, JVC 2.5" DVD/Mp3 Player.
- Zoso124
Let me throw in my 2 cents. Not worth it, I think its a little too light. Your not gonna see a huge improvement on a dyno. The stock weight of the K8 FW is perfect. These guys say it does cause they like to sit at McDonald's and rev their engines at the girls.
Get some light wheels and your car will be much faster!
Mike Evans
Gone:
Gone:
- XxantwawnxX
Hahah i do not partake in that!Zoso124 wrote:Let me throw in my 2 cents. Not worth it, I think its a little too light. Your not gonna see a huge improvement on a dyno. The stock weight of the K8 FW is perfect. These guys say it does cause they like to sit at McDonald's and rev their engines at the girls.![]()
It is light but i had np pulling out of my driveway for the first time...hell i barely noticed a diff in drivabilty. Maybe its because all my other mods.
Mnemonic
I have one, love it for the quick revving and getting me into the upper rpm range, though i have to admit it sorta sucks not having a 1st or 2nd gear really, and anyone that has one knows what i'm talking about
And as for the Daily driving portion, well let me put it to you this way, i have delivered many of pizzas while in college with a klze powered mx-3 and a fidanza flywheel, Once you get to used to it, its not really a problem.
Though a few buddies of mine do have a theory that the lighter flywheel does hurt upper rpm power, basically on the belief that the weight of the flywheel actually will help the intertia (sp) in the high rpms. basically saying that the weight will actually help, wasnt really sure how that worked, but when he said it, sorta sounded like an intresting theory, though a theory none the less, there was no actual hard facts.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Hmm, yeah, I can kind of see that. Heavier flywheel would help keep the engine momentum, so less energy would be spent keeping up the existing revs, and more would be spent increasing the revs.Mnemonic wrote:Though a few buddies of mine do have a theory that the lighter flywheel does hurt upper rpm power, basically on the belief that the weight of the flywheel actually will help the intertia (sp) in the high rpms. basically saying that the weight will actually help, wasnt really sure how that worked, but when he said it, sorta sounded like an intresting theory, though a theory none the less, there was no actual hard facts.
Although maybe I pulled that out of my a-- just now. Who knows.
- mr1in6billion
Yup, you did.Whisper wrote:Hmm, yeah, I can kind of see that. Heavier flywheel would help keep the engine momentum, so less energy would be spent keeping up the existing revs, and more would be spent increasing the revs.Mnemonic wrote:Though a few buddies of mine do have a theory that the lighter flywheel does hurt upper rpm power, basically on the belief that the weight of the flywheel actually will help the intertia (sp) in the high rpms. basically saying that the weight will actually help, wasnt really sure how that worked, but when he said it, sorta sounded like an intresting theory, though a theory none the less, there was no actual hard facts.
I can see where this might come from though. Two objects spinning, equal forces applied to slow them, the lighter one will slow faster. Seems like the longer lasting heavier object is better for cruising. However, if you are trying to keep the revs stable you are battling against the force that is trying to slow them down, the momentum of the object is stable and thus becomes irrelevant. Speeding up you must overcome the force that is holding you back and the impulse of the object, in which case, less is better.
So you can speed up faster, slow down faster, and cruising is unaffected. Aside from the cost it sounds like a win win to me. It is a bit costly and time consuming though.
yeah when you have one of these you fly through 1st and second...Mnemonic wrote:I have one, love it for the quick revving and getting me into the upper rpm range, though i have to admit it sorta sucks not having a 1st or 2nd gear really, and anyone that has one knows what i'm talking about![]()
I agree, but if you happen to be changing the clutch, throw out bearing, or putting in an LSDmr1in6billion wrote:So you can speed up faster, slow down faster, and cruising is unaffected. Aside from the cost it sounds like a win win to me. It is a bit costly and time consuming though.
and as far as revving at the girls at mcdonalds?LOL where did that come from?! We don't want to hear about YOUR free time activities
Oh and I DO have some lightweight wheels already so + the flywheel -that's the best of both worlds right?
- XxantwawnxX
right.Mooneggs wrote:yeah when you have one of these you fly through 1st and second...Mnemonic wrote:I have one, love it for the quick revving and getting me into the upper rpm range, though i have to admit it sorta sucks not having a 1st or 2nd gear really, and anyone that has one knows what i'm talking about![]()
I agree, but if you happen to be changing the clutch, throw out bearing, or putting in an LSDmr1in6billion wrote:So you can speed up faster, slow down faster, and cruising is unaffected. Aside from the cost it sounds like a win win to me. It is a bit costly and time consuming though.- you might as well upgrade your flywheel!
and as far as revving at the girls at mcdonalds?LOL where did that come from?! We don't want to hear about YOUR free time activitiesand plus if you are revving at those girls anyways you might have other issues - LOL
to each his own I guess...
