Brakes??? All Disk vs. Front Disk + Rear Drum??
Posted: October 2nd, 2001, 11:09 pm
by simo711
Alright. I have a good one for you guys to answer. What is better to have on an MX-3? All Disk or Front Disk + Rear Drum...let me know. Also, how much would it cost to have the rear brakes be disk??? Just a curious question. Chris
Re: Brakes??? All Disk vs. Front Disk + Rear Drum??
Posted: October 2nd, 2001, 11:49 pm
by finchuck
i'm not sure what would be better but i had the rear brakes replaced with disk and it was about $200
Posted: October 3rd, 2001, 12:11 pm
by fender bent
i think there might be a little better braking with rear disk brakes. however, my rear disk brakes froze and i have to replace them for a lot more than a replacement for drums.
Posted: October 3rd, 2001, 12:42 pm
by Marlon
how dose your e-brake work with 4 disk brake<p>[ October 03, 2001: Message edited by: Marlon ]
Posted: October 3rd, 2001, 1:51 pm
by cjthor
Hello,<BR> I have been contemplating this for a while and have decided to just stick with front disc/ rear drum. In order to do the swap correctly you have to change the following items.<P>1. Master cylinder<BR>2. Proportioning valve<BR>3. Calipers<BR>4. Rotors<BR>5. Emergency Brake Cable<BR>6. Rear Spindles<P>I am sure I am missing something else. Your Front brakes do most of the braking anyways so I decided to just get cross drilled rotors and some nice pads from corksport for the front and keep the rear drums. Also, if you really think of it, rear disc brakes weigh more than rear drums.
weight reduction baby!!!
