Brakes??? All Disk vs. Front Disk + Rear Drum??
simo711
Post by simo711 »
Alright. I have a good one for you guys to answer. What is better to have on an MX-3? All Disk or Front Disk + Rear Drum...let me know. Also, how much would it cost to have the rear brakes be disk??? Just a curious question. Chris
finchuck
Re: Brakes??? All Disk vs. Front Disk + Rear Drum??
Post by finchuck »
i'm not sure what would be better but i had the rear brakes replaced with disk and it was about $200
<A HREF="http://www.finchuck.com" TARGET=_blank>Finchuck Online</A>
fender bent
Post by fender bent »
i think there might be a little better braking with rear disk brakes. however, my rear disk brakes froze and i have to replace them for a lot more than a replacement for drums.
92 1.8L V-6 red baby rocket
Marlon
Post by Marlon »
how dose your e-brake work with 4 disk brake<p>[ October 03, 2001: Message edited by: Marlon ]
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
cjthor
Post by cjthor »
Hello,<BR> I have been contemplating this for a while and have decided to just stick with front disc/ rear drum. In order to do the swap correctly you have to change the following items.<P>1. Master cylinder<BR>2. Proportioning valve<BR>3. Calipers<BR>4. Rotors<BR>5. Emergency Brake Cable<BR>6. Rear Spindles<P>I am sure I am missing something else. Your Front brakes do most of the braking anyways so I decided to just get cross drilled rotors and some nice pads from corksport for the front and keep the rear drums. Also, if you really think of it, rear disc brakes weigh more than rear drums. :) weight reduction baby!!!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
