Clutch for BPT
nolig2278
Clutch for BPT
Post by nolig2278 »
i believe i need a new clutch as it slips now and then in4th and 5th.
Suggestions for a daily driven and occasional track use and abuse on highway 15 psi BPT. I launch a lot.
Want to spend roughly 300 and if a flywheel cuts gas then I might splurge on that.
I had an ACT with my setup go bad according to a shop and do 1k in repairs(supposedly, i say shop lied)
I will do this myself as when i put in the act, but I am not found of act as they are a bit hard on the foot.
I have read a bit on fidanza and like the 4.3 and was just told fidanzas are re-branded Specs?
Thoughts and suggestions are welcome
thanks
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
[url=https://gilon.levinsonltd.com/mx-3.html[/url]
houls69
Post by houls69 »
ACT are great, I have had mine in a year and its fine. I opted for the extreme pressure plate and have no problems with it. It is hard on the foot though!
Return to “Transmissions”
