Car RPMs to high?
PJJ
Car RPMs to high?
Post by PJJ »
HI,
Looked at a 96 v6 MX3 on the weekend. At 50 mph (80km/hr) the rpms were 3000+. This can't be right? The engine sounds fine at idle.
An ideas what could be wrong? Didn't smoke, compression tested ok. Incorrect timing belt install?
Thanks
tysoe
Post by tysoe »
don't know but I noticed GS does about 4200 rpm at 80mph in fifth which is a little more than my miata
In the v6 mx-3 idle in neutral is about 670 rpm and in gear idle is roughly 1200 for me.
So the MX3 seems to have pretty close gear ratios, especialy in 1st and 2nd
PWRD_BY_HKS
Post by PWRD_BY_HKS »
gears are short... that is not too bad...what gear were you in...
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
PATDIESEL
Post by PATDIESEL »
Sounds about right to me if on a manual trans MX-3, V6.
PJJ
Post by PJJ »
I was in 5th gear , 50mph and rpms were 3000ish.
Thanks for the responses ... it seemed like high rpms for a v6 too me.
PWRD_BY_HKS
you are forgetting its a 1.8 v6
VICTORIA RACING
hharb
Post by hharb »
over 3000 at 80km/h thats revving a little too high, i will double check tomorrow but i think my car does a little over 3000 rpm at 100km/h, so 80 should be a little below 3k
fieromx3
Post by fieromx3 »
110kmh is dead on 3500rpm
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
Jimbo1177
Post by Jimbo1177 »
I know mine is just shy of 4000rpm at 75 in 5th, so 3000rpm at 50 doesnt sound unreasonable.
hharb
Post by hharb »
alright, so i checked yesterday and my car is dead on 2.5k at 80km/h in 5th gear. and dead on 3k at 95km/h in 5th gear unless my car is revving too low your car is revving a little too high
