probe 2.5 air intake
Dropped mx3
Post by Dropped mx3 »
Will a probe 2.5 air intake work on my 1.8 V6?
hgallegos915
Post by hgallegos915 »
Yes it will, you need to CHOP the elboy.. and turn it 180 degrees, use a rubber coupler and walla.. fits right in like a glove (in the fender cavity) Cheaper than an integra intake.
-hec
Dropped mx3
ok thanks what one should i order?
eBay Motors: 93 94 95 96 97 Mazda MX6 626 Ford Probe V6 Air intake 1 (item 230106672325 end time Mar-25-07 23:35:3
eBay Motors: 93-97 Mazda MX-6 626 Probe GT V6 Air Intake 94 95 96 LS (item 180099129958 end time Mar-26-07 12:27:2
okingo
Post by okingo »
Been looking into doing my K8 as well. Are you going to do a cold air intake?
MX-3 V6 - K8 - Alpine Stereo, Amps, Speakers ICE. Power flow stainless custom exhaust system cat back and de-cat pipe. Induction kit next.
Dropped mx3
im not sure i might just put the short one piece ram air on it
hgallegos915
Get the one that goes all the way down to the transmission (ON THE PROBE GT) then ill show you where to cut, its quite easy :) It fits exactly like the integra intake but cheaper. it sits UNDER the water resevoir (i relocated mine) on that fender well gap thing.
-hec
