Hey i just fired my car up today....I put an MSD Blaster 3 coil and a new HEI module
it started up great ......but i have no stock tach....i used the 1k resistor and hooled it up just like in the diagram....but i can't get it to work...and i tried to put it in diagnostics mode to set the timing but it wouldn't start it just turned over ....then after that.....it turns over for a long as time b4 its starts up and runs rough real rough for alittle bit
but then it'll run fine???
I want to get this working ASAP
							Problems after installing external coil
				mazdaspeedmx_3
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
