Best transmission oil
nightfire
Post by nightfire »
So the MX3 I bought has ~208k km on it, and as far as I can tell it's the original clutch. It's got about 10,000 more km left on it, I'd say.
I plan to swap in the KLZE in the summer, but in the meantime, the transmission feels a little rough. I'd like to flush and fill it with new oil.
Is there a consensus on what the best oil is? I used 80/90 synthetic gear oil on my escort and it was very smooth, even in the winter. Most people recommend the merk/dexron 3 ATF fluid though.
Experiences? I don't have the chilton's manual yet.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Limegreen mx-3
Post by Limegreen mx-3 »
u are stick right if so why would u want to put auto fuild in a manual trans
nightfire
Post by nightfire »
Limegreen mx-3 wrote:u are stick right if so why would u want to put auto fuild in a manual trans
Yeah, manual.
Nevertheless, this was the recommended fluid for the Escort's transmission... I'm guessing not for the MX-3?
- Gord
jaydog5678
Post by jaydog5678 »
You can run an auto trans fluid in our gearbox's. The G and the F series. They were designed to use both types of fluid.
Personally, I use Royal Purple 80-90 synthetic and will only use this gear oil from now on. It's roughly $9 a quart.
JWMotorsports
Post by JWMotorsports »
Lucas 80w90 Trans Fluid w/ 1 bottle Lucas Trans Fix.
15,000+ miles on a Pro-LX box at 400+WHP and hasn't broke.
Only down side to adding the Trans Fix is a cold gear box needs to be shifted gently for the first couple blocks...after that it loves to be slammed through the gears!
Return to “Transmissions”
