a v6 alternator in my 1.6?
i was wandring if i can put a alternator out of a 1.8, 2.0, or 2.5 in my 1992 1.6 mx-3...what i can get one out of and what year...thanks
-Ryan
PM me if you have one for sale and your not to far away...
-Ryan
1992 mx-3, white, 1.6 sohc, 5 speed, custom: intake, interior and exhaust
what do you mean by upgrade options?...i called the local alternator and starter shop and they said that the gs and rs have the same mounting stuff and they have the same voltage regulator and stuff but he just wasnt sure...he never even saw an mx-3 before...
- 2fazed
He wasn't sure, cause he doesn't know. The GS has a bigger amp alt. You have to mount the GS different in the RS. But it will fit.delpy32 wrote:what do you mean by upgrade options?...i called the local alternator and starter shop and they said that the gs and rs have the same mounting stuff and they have the same voltage regulator and stuff but he just wasnt sure...he never even saw an mx-3 before...
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
- Josh
the SOHC 1.6 uses a 65amp
the DOHC uses a 60amp for some reason.
a GS uses an 80 or something like that.
there are plenty of write ups on it use th esearch function to find what you want to know. the only difference between the mounting of the GS and RS is the bolt go's in from the opposite side of the ALT. it deffinatly helps with sound systems, and dimming of head lights.
- ryan_Fuerte
hey
if your gonna put in an alternator from a v6 why not get an alternator from a 96+ millenia, they put out around 110 amps i believe.
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
- Tunes67
Check the faq sections.. the information is posted and available.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
- Josh
the mellinia alt isnt plug and play. you need to mod the wiring a bit
- Limegreen mx-3
[quote="Josh"]the SOHC 1.6 uses a 65amp
there are plenty of write ups on it use th esearch function to find what you want to know. the only difference between the mounting of the GS and RS is the bolt go's in from the opposite side of the ALT. it deffinatly helps with sound systems, and dimming of head lights.[/quote]
mx-3 GS and 2nd gen V6 MX-6 have 90 amp
ur sliping on me josh
- Josh
i know i know, i said 80 or SOMETHING. i had been running one for years, till i did my BP swap. cant find a damb v belt pully that will fit. im told the seccond gen rx7's used a v belt. and have a bigger shaft so it should swap onto a GS alt.Limegreen mx-3 wrote:mx-3 GS and 2nd gen V6 MX-6 have 90 ampJosh wrote:the SOHC 1.6 uses a 65amp
I believe the issue with the alts is the pulley size. I tihnk what was said will happen is that the GS alternator will be underdriven, where it wont be efficient at idle speeds. But i'd definitely look into it first
