This one, from March of last year, was good. PATDIESEL said:
I'm familiar with cylindrical 2-post coils, but the small E-coil that is in my 93 mx-3 RS is new to me. It seems the coil has a 4 wire connection, not just 2 posts. Is there an external coil that is in the 30k to 40k range that can be added without adding a suplpemental ignition control (such as the MSD 6AL)? Are there mods to allow for the use of the 2-post coils?...First the stock ignition is weak for the motor and for a high performance motor at that. Of course this is inherent in any distributor set-up, especially with an internal coil. So a good external coil will definately help in the top end when the stock internal starts to run out of power.
Indexing and opening the gap is a good idea and will also benefit from the external coil. ... I'd also suggest some 8.5mm Magnacore wires to go along with the upgrade.
As for the Mega Squirt being needed you know that there are plenty of other systems that will controll the spark if that is your aim. I'm currently working on the wiring for a MSD multi-coil set-up myself, but really won't have the parts to acutally assymble and try it out till later this year.
Why not ignition control? Well, ignition control seems to still rely on the ECU for timing (as far as I know), the distributor for distribution, and the coil for increasing voltage. As far as I can tell, ignition control mainly extends the duration of the spark, that is the amount of time it takes for the electrical field to collapse -- almost as if the voltage to the coil is turned off slowly, instead of instantaneously.
I should think that with a sufficiently strong spark, that the duration of the spark is of negligible difference. Of course there are other benefits from ignition control, such as rev limiting and rev-holding for fast starts. Maybe I am wrong... Your input is greatly apprecaited -- no need to flame me if you are a strong believer in supplemental ignition control.
