Fidanza Flywheel
slimmyslim1420
Fidanza Flywheel
Post by slimmyslim1420 »
What are the actual gains going to a fidanza 9lb from the mx-3 clutch on a ZE? I'm not looking for exact HP numbers, but maybe some estimates and personal experiences. Also what are the advantages, like more take off? top end? I am looking at buying one but $400 is a big investment so if it dosen't help a lot then I probably won't get it just yet, and go with something else. All responses are appreciated.
thanks.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
Steeb
Post by Steeb »
http://www.whizwheels.com/Tips/lightenflywheel.html
a flywheel will not make your engine make more power but it does make it more responsive due to the decreased weight that the crank has to spin.
i love my fidanza and exedy street disc. i only wish the fidanza came in a 5-7# weight instead of 9-9.5#'s
hgallegos915
Post by hgallegos915 »
I think fidanza only helps you in like 1st anbd maybe second gear.
http://www.youtube.com/watch?v=iDmPfJ3VHj0
see in thnat video I am the blue mx3.. the loud one is the red mx3. he laun ches like at hmm 3 thousand rpms. I launchyed at 1.. lol see how we both shift to second gear at the same time? and to third i shifted like a half a sec earlier than him. we both shifted at around redline. Imagine if i get me some drag radials or better suspension..
back to the subject i think fidanza is worth it if you got a ze.
-hec
mx3autozam
Post by mx3autozam »
first of all 5-7pounds is waaaaay to light
You don't gain anything by a fidanaza. it just free's up horsepower that is being taking away by the heavy flywheel.I think it does help in all gears. I personally love mine!
93 Mazda MX3 KLZE Turbo
papa roached
Post by papa roached »
love mine, put it in when i did the swap so i couldnt give you gains but it rips through first and second like a rocket especially when i had the lower geard stock tranny with good tires
jbaysinger
Post by jbaysinger »
What's the weight of the stock flywheel? How much are you saving with the Fidanza?
Jeff Baysinger
'92 MX-3 GS
http://www.generic-racing.com
jdMx-3KID
Post by jdMx-3KID »
i believe hectors (hgallegos915) weights 9 lbs....the biggest difference i noticed after he got his ...i revs up alot faster than with out it.... its a mod you shold consider.... you have basic bolt ons...personal opinion dont hold me to it
FORMALLY KNOWN AS PWRD_BY_HKS....
ZE POWERED MX TO THE THIRD
Steeb
Post by Steeb »
i believe stock is 16#'s
PATDIESEL
Post by PATDIESEL »
Stock MX GS is 12 pounds. As for usefullness... I like the way it drives, but every day would get old to me. For 400 I'd buy a MegaSquirt. That gives WAY more HP gain than any weight flywheel would.
