Sim's RS
Posted: January 4th, 2007, 7:38 pm
I decided to start a thread on my car because it's going to be a long project.
I was rebuilding the B6 to turbo it after but after I made a list of all the parts and all the prices I thought it would be a lot cheaper to buy a BPT and swap that in instead. Here's the list of part I made to build a reliable
B6 turbo...prices are some what accurat
PROJECT MX-3 1.6 Turbo 400HP
PART # 1 (engine building)
-block glass beaded
-honed 80$
-head shaved 20$
-3 angles job 200$
-valves guides 150$
-waterpump 100$
-pistons 500$
-rods 500$
-stainless valves 350$
-valve springs 200$
-cams 450$
-cam gears 200$
-timing belt 80$
-ARP Head Studs torqued to 70lb/ft. 110$
-Fel Pro MLS or Cometic MLS head gasket 100$
-shim a NEW oil pump 0.200" (relief spring seat sits on cotter pin) will
give you the proper oil pressure to keep parts from scrubing and lifters
from deflating at high loads 150$
-new bearings 50$
-Clutchnet Red 3X Pressure Plate
Clutchnet Red 6puck sprung hub disc, Yellow Fibre-Carbon, or Yellow Kevlar 300$
sprung hub discs
TOTALPART # 1 = 3540$
PART # 2 (ECU Tunning)
-Microtech LT-8x Standalone from Corksport w/ 3-bar map sensor or haltech 1000$
-EGT Gauge
Boost Gauge
PLX Wideband 02 Gauge 215$
-Accel 300+ Ignition w/ coil 230$
-Accel 300+ Plug wires or Magnecore KV85 Plug wires 70$
-NGK V-Power Plugs
-Whalbro 255lph High Pressure fuel pump 150$
TOTAL PART # 2 1665$
PART # 3 (Boosting)
-Garrett GT2871R with a 63ish A/R exhaust housing (I recommend external
wastegates & dump to atmosphere...better boost control and higher peak HP
output) 1500$
-Tial 38mm or 44mm wastegate with atleast a 2 1/4" dump tube 200$
-3" exhaust....or larger after the firewall w/ 3" down pipe 500$
-The largest intercooler you can afford (Corksport has the hook up) 200$
-2.5" IC Pipes 200$
-Adjustable Fuel Pressure Regulator with 1:1 boost ref. rising rate 80$
-650cc fuel injectors 550$
-some meaty tires....unless your in a burn out competition
TOTAL PART # 3 3230$
Project total = 8435$
compared to I found a BPT from a GTR for 1800$
-block glass beaded
-honed 80$
-head shaved 20$
-3 angles job 200$
-valves guides 150$
-waterpump 100$
-pistons 500$
-rods 500$
-valve springs 200$
-cams 450$
-cam gears 200$
-timing belt 80$
-new bearings 50$
sprung hub discs
-EGT Gauge
Boost Gauge
-NGK V-Power Plugs
PART # 3 (Boosting)
output) 1500$
-2.5" IC Pipes 200$
