EMS Question
- Custom_V6_Limited_SE
EMS Question
I'm looking to get an engine management system that will allow me to use EGTs. What systems support that? The Haltech E6X doesn't support them does it?
'93 MX-3 GS SE:My Mods
I know the AEM units offer EGT based fuel correction...can even do individual cylinder A/F correction with a EGT probe in each port.
Other systems may be able to be programed to use an input channel(s) to do fuel correction but you would have to build a circuit to output the EGT probe's voltage to a readable range for the input your channel(s) your using.
I'm working with the 6-cylinder engines. The AEM says it only supports 4 EGTs. Would the TEC3 do six? I didn't see anything about EGTs on their info page. If not, I guess I'll just have to settle for the MoTeC M600
![Welder :welder:](./images/smilies/welder.gif)
![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
I believe there are add on units for the AEM that allow you to add addition EGT probes. I'd recommend contacting Howard at AR Fabrication in Winchester, VA. He is an AEM EMS systems guru and a authorized AEM dealer. Tell him Jeremy Miller with the black n white turbo MX-3 sent you.
http://www.arfabrication.com
1-540-722-3966
1-540-722-3966
