ok.. I try to start my car, it only keeps turning but no start.
Spark test ok, battery is charged, i changed the fuel pump and filter.
Running out of ideas, any help would be appreciated.
Car wont' start
- XxantwawnxX
Fuel injectors(highly doubt it) Crank angle sensor or cam sensor maybe. timing maybe off...just some things to check into too.
