PUlling tranny
- papa roached
PUlling tranny
Can you get the tranny out of the car just by dropping all the mounts save the pass side one, i know it was tight on my RS when i did it and its time to do it on my GS now and wanted to know before i go to far into it
yes. pull axles, lower cross member, air box, battery trey loosen upper trans mount
then pull bell housing bolts & slave cyl
you need sunthn under the engine & trans to support both
the top pass mount WILL NOT support the engine alone you mus use a jack or a transverse engine support.
remove top trans mount
once engine is stable start lowering trans i like th use starter as a handle
its tight but it will drop out . vairing the engines angle will help get trans out
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
- XxantwawnxX
Very important, do not forget to un bold the flywheel very carefully. Find a box somewhere in your house. Package it up and send it to me.
