Hey guys, lookin for a 92-94 GS (must be 4 wheel disk);
- front calipers brackets (they bolt your caliper to the spindle)
- the rear flex lines that go from your subframe to the caliper
- the proportioning valve (sits against your firewall off to the left, has about 4 lines coming off it)
- both rear ebrake cables with the main handle cable as well!
Located in ontario, canada.
thanks!
JACK.
[WTB] 92-94 MX3 GS Caliper brackets, flex lines, ebrake
Mazda_Powered
.::Mazda::speeD::.
working on the 2nd part
- mitmaks
ive got flex lines (rubber) pm sent
