150xxx on chassis
41xxx on motor
motor came to me as a straight neck ze and I just swapped manifolds so it is a real ze.
Motor has new water pump, timing belt, Rad hoses, accesory belts.
Pheno spacers, throttle body and IM
Probinators Ecu (have stock as well)
stage 2 clutch
k8 flywheel resurfaced 700 miles ago
poly filled mounts
Hei mod
p/s and a/c completeley removed for weight
rx-7 fuel filter
b&m short shifter
axle back exhaust w/ silencer
test pipe (I have cats)
brand new drivers side axle(autozone with warrenty)
clear taillights
clear corners
suspension tech sprigs (1.5 in drop)
Tocico shock upgrade
Camber bolts (car can allighn within factory specs)
17 inch white axxis touring cup rims with extra 5th rims (no longer made)
newer 205-40-r17 kuhmo tires
the bad-
needs a window switch. I have it so you can get the windows up and down but would need a new switch for it to be pretty.
passenger axle will need replacement soon, just ran out of money for the project.
throttle body needs to be cleaned to idle correctly.
asking price is $3300 or best offer
would also be interested in trading for a truck
email is static_x_@hotmail.com
here are some pics...
