Is a 1.5inch drop good if I am going to put on 18s?
Posted: October 15th, 2006, 8:33 pm
by Juans_93_MX3
I plan on putting 18s on my car but I am wondering, would 18s be too big with a 1.5 drop?
Posted: October 15th, 2006, 10:16 pm
by solo_ryder
Nope, I had a advertised 1.3" drop and it settled at like 1.8" and still had lots of room, never rubbed. I was running 215/35/18 , but, if you have not got the rims yet dont buy 18's they are sooooo bumpy and they dont look that good IMO unless they have a spoke that curves in.
Posted: October 16th, 2006, 12:43 am
by Juans_93_MX3
The spokes on mine curve in
So if I buy 1.5inch lowering springs the car will settle in at 1.5 right? Or would it settle in at like 2inches?
Posted: October 16th, 2006, 12:39 pm
by solo_ryder
It will proly settle to 1.8"- 2" area, that will be ok still, the 18's in comparison to your 15's with stock tires are not to much different
Posted: October 17th, 2006, 11:06 am
by Juans_93_MX3
I hear that with 18s my ride is going to suck though
Anyway, I only plan to use them for looks
Sometime within the next couple months I am looking into getting a KLZE and a 5speed swap.
When i go to the track I will just put the stock wheels back on
Anyway, I only want a 1.5inch drop.
What do you guys recommend? A 1inch drop so that way it settles in at 1.5inch?
Posted: October 17th, 2006, 6:15 pm
by solo_ryder
Yea, try going with suspension techniques springs, they are a 1.3" drop and settle at 1.8". Eibach is also a drop that lowers just below 1.5" as well.
Posted: October 20th, 2006, 1:02 am
by Juans_93_MX3
I am looking into Eibach 1.5inch drop but just to comfirm, it has to settle in and when it does it will be a 2inch drop?
I never knew that about lowering springs
Posted: October 20th, 2006, 11:05 am
by solo_ryder
Those Eibachs will settle at about 1.5 man. I have seen them b4
Posted: October 20th, 2006, 4:01 pm
by precidian
you will be fine with the 18s. Just make sure that the offset of the wheels are approx 38mm.
Posted: November 19th, 2006, 12:11 pm
by nolig2278
I have had the eibachs and they seemed to have settled more than 1.5 inches in the front. i love the look but i have rubbed a little and i ride with 195 50 15 in front. 205 it front will rub inside during turns with my setup.
currently it only rubs on the splash guard with a level change in the road, and this might be due to a old suspension.
