Hey Guys, I recentely finished my turbo project with all custom 2 3/4" intercooler piping and i am using a stock GTX manifold and GTX turbo but want to upgrade to a larger turbo and nicer looking manifold but am not sure are my choices ? I have the 1996 DOHC 1.6 and need some advice from the turbo experts. This car is 99% for show so bigger is obviously better but i know you cant put anything larger on the stock GTX maniford and turbo housing so what are my options? Here is what i currently have:
GTX turbo VJ-20
GTX Turbo manifold
2 3/4" custom stainless exhaust
2 3/4" custom stainless intercooler piping
spearco intercooler 30-12-3
aeromotive Rising rate Fuel regulator with all braided fuel lines
Greddy Turbo 2 controller
Greddy Turbo timer
NGK 9mm wires
NGK platium plugs
Greddy Type-R BLOV
Stock Mazda MAFC
Stock computer
stock injectors (need 310 injectors soon enough)
stock internals (for now)
thanks
MX3Extreme
Want to Upgrade?
I can hook you up with a custom manifold and any turbo you like. Check out my car domain page and you can shoot me an email if you like. My email address is jwmmotorsports@hotmail.com
With your size IC pipes you have in place you could use a Garrett GT 3076R like mine or the GT3040R w/ a .63 A/R exhaust housing. My turbo has the .82 A/R exhaust housing and can hit 30psi by a little before 5500rpm. I can fabricate any kind of manifold you like to put the turbo any where you like. Use a Tial 44mm wastegate, unless money isn't an issue then go with the monster HKS GT II 60mm or the Greddy Type CH 56mm and a stepped external dump tube
to atmosphere. If you don't care about spool times or driveability put a GT4088R or a GT42RS on it....but don't expect it to spool unless your spraying it down low Two 10lb bottles with in the back with a GT42RS under the hood would look flat out SiCk
