E-test time
panheader
E-test time
Well, I picked up my '93 MX-3 V-6 5 speed Friday, and now it's time to safety and e-test. The safety should be no prob, it's in real good mechanical shape and everything works, but the e-test may be another matter. It runs real well but you never know. Does anyone have any tips/tricks/ideas about any preventive things to check or do to help it get thru the first time? I dread these things, and I'd really like to make it the first time. Thanks
- mr1in6billion
- Tropical Emerald 1993
sampsonmx3sv
You probably already know, but they say to let the car run for ten to fifteen minutes before going there. After my klze swap with different intake, and a mess of vacuum hoses I passed with flying colors.
93 gsr,KLZE with millenia intake, phenolic spacers, HKS intake, limitedslip-auto to manual conversion,centerforce clutch, 75hp NOS wet kit, MSD with blaster coil, white gauges, pacesetter shortshifter, Tenzo seats, lowered 2 inches, Konig Traffik white rims, cat back exhaust
sampsonmx3sv
If everything is hooked up you'll be fine. I was super nervous though too.
panheader
Well, it's all over finally and I'm legally on the road. The people I got tires from did the safety, and all they could find was one bad (right) tierod end. Not too bad considering there's 400K km clocked on it. The e test wasn't as simple. I knew nothing about the history of the car, so I just took her in with just an oil change and good and warm from a highway run. Passed on all the idle tests, but failed (FAILED BAD...I'll post numbers at the end) on the driving speed, all three gasses. I didn't have a lot of faith in their test, but figuring it was high in all 3, that tends to point to the cat. I found a decent price locally and got a cat (universal) put on. Took her on the highway for a few minutes, and took it to someone I trusted more. This time it passed on 2 of the driving speed ones, and barely failing the third. The kid that did the test told me to put on wires and plugs and bring it back. I took his advice and tuned up, and noticed a difference in the way it ran right away...took it back yesterday and breezed through it. Amazing what a cat, plugs and wires can do.......
HC ppm(max allowed 68) went from 146 the first test down to 23 the 3rd
CO% (max allowed 0.38) went from .59 down to.01
NO ppm (max allowed 526) started at a whopping 1162 and went down to 218.....Finally, I've had this car 2 weeks and it's legal at last!
- mr1in6billion
