Page 1 of 2
In the middle of the ze swap(I AM DONE!)
Posted: September 9th, 2006, 10:06 pm
by hgallegos915
Well im in the middle of the swap, 7 hrs and the engine is out. I must say i had a beattch of a time with a few setbacks. The rear mount was STUCK.. glued on like a suckaa.. had to lift engine sideways to get it out. The driver side exle will NOT COME out..its seized in.. i did take it off the trans so it came out ok. The exhaust bolts where also seized but i got them out after playing with them for a good half hour.
Last but not least, my allergies and mud all over the place..YAY
Its a pain but i should be done by monday or tuesday .
Need to find where to get something to plug the manifold hole and to get the de ecu from my friend.
Posted: September 9th, 2006, 10:20 pm
by Mnemonic
put the header in a vice, remove the part with the hole in it for the egr pipe, then get a 17mm bolt with a washer on the inside of the piece with the hole, torque it down and boom instant fix, dont have to go get any parts just look for a spare bolt. Both me and barry did it this way and works like a charm
Posted: September 9th, 2006, 11:29 pm
by PATDIESEL
Just make sure the bolt isn't so long that it pokes into the exhaust stream inside the header. If it is too long then thread a nut onto the bolt, cut it to the right legnth, then twist the nut over the cut end a few times without taking it off. It will worrect any pinched threads so that you can thread it into the header easily.
Posted: September 10th, 2006, 4:02 am
by hgallegos915
I meant the hole under the millenia style manifold. well the hole.
Posted: September 10th, 2006, 10:08 am
by RizzeRocket
what would happen if u dont have that hole plugged in?
i dont think i ever did it on mine
Posted: September 10th, 2006, 10:11 am
by Mnemonic
you have a very large vaccuum leak, your car will barely run and if it does it will run like crap
Posted: September 11th, 2006, 12:09 am
by hgallegos915
Ok small update, the engine is IS, i stayed up late connecting the exhaust..gosh that was painfull. The rear mount was a pain in the fingers! I had to take cross member out and align and screw it in..then the pilyutherane filled mount wripped to shreds... so iguess 80 grade utherane isnt enough.. Anywho tomorrow i clean the intake manifold tun it on used oil for a few minutes then flush and fill. I fixed my transmission seal part no 2007N / I cant wait to get it running. IUll be using klde ecu and k8 vaf..but im sending to probinator for chip de vaf and de ecu iguess.
Posted: September 11th, 2006, 1:08 am
by PATDIESEL
You must not have let the mount cure or something. Either that or you used the Home Depot crap and not real 80A urethane. I doubt I could get mine to rip with a tug boat pulling each side.
As for the hole under the intake, you have to make a plate for it and use some sealant around the edges to create a vacuum seal. Like Brian said your car will not run with that hole opened.
Also, what did you do to the cross member? It shouldn't need to be messed with.
Just trying to help save you more headaches down the line, not trying to be a party pooper.
Grats on getting the motor set in.
Posted: September 11th, 2006, 9:43 am
by RizzeRocket
i guess i better plug that in.
and i didnt notice the car run like crap either but i better do it
Posted: September 11th, 2006, 12:17 pm
by hgallegos915
well yeah ill plug it in, weird thing tho is that my friends ze .. he does n ot have it plugged in and hes running high 14.. strange. I think ill slap the de intake for now until i properly seal it. The mount i let it cure for over 2 months, mayve i didnt mix it well. Maybe it was cheap utherane. Got it online for 32 dllrs. Ill rem,akle it and this time use of a more concentrated solution. Thanks for the help pat. The cross member i dont know why i always have a hard time with the rear mount. I did manage to get it installed and it sits properly now.
Posted: September 13th, 2006, 8:58 pm
by slimmyslim1420
RizzeRocket wrote:you have a very large vaccuum leak, your car will barely run and if it does it will run like crap
The hole on mine is not plugged for the simple fact that I looked in it and it was blocked off. So no vaccum leak. Look up the hole before you try to plug it it may not even go anywhere. You have to remember if it is Jspec it didn't use egr which is what that hole is for so rather than make two completely different manifolds mazda just blocked off the Jspec one and left the US spec one open. If you have a manifold from a US millenia block it but if it came off of a Jspec im pretty sure you won't need to.
Posted: September 13th, 2006, 10:43 pm
by hgallegos915
yeah i left open and it works fine, no leak..odd.
Posted: September 14th, 2006, 9:25 pm
by hgallegos915
OH MY GOD thi9s engine is FAR FAR more superior than the kf of course it pulls and PULLS and PULLS . I dont know if my vris is working rightn but dayum My 1st gear is not there.. if i floor it half ways the tires spin out BIG time.. oh BTW
the priblem was a bad wheel hub. Replaced with a junk yard one and good to go! Also got a new halfshaft from autozone lifetime warranty YO!
Posted: September 15th, 2006, 4:54 pm
by hoffman_BMX89
hey how do u get the halfshaft out from the jack shaft i am gonna have to repace mine soon due to a riped boot
thanks
Posted: September 15th, 2006, 5:26 pm
by atlantamx3
hgallegos915 wrote:OH MY GOD thi9s engine is FAR FAR more superior than the kf of course it pulls and PULLS and PULLS .
Uhh YEAH.
Thats why we were saying to go with the KLZE when you were all hyped up about the KF.
Anyway- congrats on the new motor!
