Ac wont turn on
Ac wont turn on
Ok i checked with a shop and they said the first time 80 dollers to fill her up i was ok then they found a leak 10 bucks then the cost on working on it 90 dollers then they find out that it wont even turn on im like WHAT they say 100 dollers and leave there for a day im like 280 dollers for ac IM GOOD but does any one have any idea why it wont turn on they say like everything is fine but it has to do with the button or wiring i think anyone got any suggestions
-Simon-
- cjthor
Re: Ac wont turn on
Thats a loooong run on sentence. They fixed a leak for 10 bucks?? How did they do that? If the AC system doesnt turn on I would guess that you still have a leak and the system knows it is not pressurizing. Did they call you after they filled it to say it wasnt working? Was it working before you took it in?XHurleyX wrote:Ok i checked with a shop and they said the first time 80 dollers to fill her up i was ok then they found a leak 10 bucks then the cost on working on it 90 dollers then they find out that it wont even turn on im like WHAT they say 100 dollers and leave there for a day im like 280 dollers for ac IM GOOD but does any one have any idea why it wont turn on they say like everything is fine but it has to do with the button or wiring i think anyone got any suggestions
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
SpikeDerailed
The A/C light wont come on if the A/C Compressor clutch wont engage. It wont engage if there is not enough freon in the system to compress. Before you have any place just add some freon, have them evacuate your system and hook it up to a vacuum pump. Your system SHOULD be able to hold a near absolute vacuum for around 20-30minutes. I five minute vacuum check wont tell you if there is a slow leak causing you to loose just minimal pressure over time.
Idealy you want your system to be able to hold a -28 or -29PSI vacuum for about a half hour. A -30vacuum would be ideal but a vacuum pump wont be able to pull a perfect vacuum on your system.
Assuming your system is properly charged and has no leaks you need to check the compressor clutch coil and bearings.
