Rear Wheel Lock up question
Blazianenigma
Post by Blazianenigma »
I just picked up a 93 MX-3 MT.
The car was sitting for a little while (7 months)
and the rear wheels are locked.
When the ebrake engaged/disengaged the wheels dont move at all.
Forward or Reverse movement is not available.
Any ideas other than taking the wheels off and the drums?
1993 MX-3 (Converting in Oct)
2004 MS6 (Repairing)
1982 Limited Edition Me (.04Hp)
Mx3er
Post by Mx3er »
get someone to bang on the wheel with a large hammer while you drive it ahead. once you get it rolling take it up to 60ish and do some braking. your problem is rust on the surface of the rotors/drums
GM tech, Mazda tunner
96mx-3
Post by 96mx-3 »
i sjut got this problem fixed yesterday cost me 150 .. i was drvving and i had the same problem the disc went bright red it was so hot ...take off ur wheel and ur capliper and ur break pads got a drill with sand paper on a bit i duno what it is and sand where the pads sit so they can move mine was stuck to the disc..
Blazianenigma
Fixed th Problem.
Took off the rear wheels...and banged the drums with a hammer.
Loosened up the rust and the wheels spin freely now.
