clutch
Posted: July 23rd, 2006, 11:02 pm
by blindfendersk8r
would this clutch work on my Escort GT 1.8 tranny? or a protege tranny?
it says it would work for a 1.8l MX-3, and the MX-3 and protege trannys are interchangable....so i assume it should fit.....please help me out
http://cgi.ebay.com/ebaymotors/EXEDY-93 ... 0008876131
Posted: July 23rd, 2006, 11:57 pm
by Limegreen mx-3
The Escort GT & Protege LXorGT use the same engine and trans G-series
The MX-3 has 3 different engines.
92-93 Mazda MX-3 RS model 1.6 sohc f-series trans
} trans are the same
94-96 Mazda MX-3 RS model 1.6 dohc f-series trans
92-96 Mazda MX-3 GS model 1.8 dohc V6 uses a different G-series trans.
The G-series trans for the 4 cly model is different than the G-series trans for the 6cly model.
90-94 Madza Protege LX model 1.8 dohc g-series trans same as the Escort GT
blindfendersk8r
Yes that is true but only among the B-series engines B6,BP,B6T,B8
G-series uses a 22 spline u'll need the clutch&flywheel
F-series uses a 20 spline u'll need the clutch&flywheel
Hope u notice the differents in flywheels.
Posted: July 24th, 2006, 8:10 pm
by blindfendersk8r
thanks i decided on this clutch
http://cgi.ebay.com/ebaymotors/EZ-90-4- ... dZViewItem
its for a SOHC protege....i assume it will still work, but im gonna find out first
Posted: July 24th, 2006, 8:19 pm
by ryanlindenberg
i don't think the SOHC one is interchangeable...
what kind of mods are you running...if you aren't running anything too crazy i would highly recommend the organic clutch disc. that 6-puck clutch is going to chatter (from what i've heard), and the take off won't be smooth. i have a BPT GTX and i have the organic disc and it is working really well.
i just looked up the clutch kits on corksport and the SOHC and DOHC are different kits. DOHC is more expensive
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Posted: July 24th, 2006, 8:31 pm
by blindfendersk8r
damn.....figures....as of now swap aside im just runnin CAI exhaust plugs wires MSD ignition and some suspension components....thanks tho, back to the drawing board on the clutch....that probably also means the axles for the SOHC wont fit the DOHC protege tranny either....
Posted: July 24th, 2006, 8:38 pm
by blindfendersk8r
also....sorry for so many noob soundin questions, i usually search, and ive tried but not workin
does anybody know if a 1.9l clutch would work in a 1.8l Escort tranny
im havin a hard time findin a cheap clutch
Posted: July 24th, 2006, 8:50 pm
by blindfendersk8r
nvm.....i found a decent 1.8l clutch....and i guess im gonna pay $200 for the axles....suuucks
Posted: July 25th, 2006, 12:14 am
by Limegreen mx-3
what is it that ur trying to do
Posted: July 25th, 2006, 5:01 pm
by blindfendersk8r
im doin the BP swap and i was lookin for a clutch and axles for the Escort GT tranny that i im usin, but i found it all so thanks
