KL68 TB. Pulled off of my car a few months ago for a bored-out TB upgrade. IAC and TPS worked OK. Asking $100
![Image](http://img227.imageshack.us/img227/2584/tb1is0.jpg)
![Image](http://img388.imageshack.us/img388/2631/tb2ds6.jpg)
Fog lights. Was going to use them on the mx-3 until I found out they were yellow, and I dont like the look of yellow fogs. I got J-Spec OEM fogs instead and installed them this week. They've both been tested and work. Asking $40
![Image](http://img238.imageshack.us/img238/495/fogsch5.jpg)
KL01 TPS. Pulled from a K8 IM that I used the IAC from. Asking $40.
![Image](http://img144.imageshack.us/img144/1701/tpsvk6.jpg)
Hatch shade mounting brackets. Brackets were not taken when my hatch shade was stolen a few year ago. Comtemplated getting a replacement, but after many deals fell through, I eventually changed my mind and I still have them laying around. Asking $5
![Image](http://img83.imageshack.us/img83/6170/shadebj4.jpg)
J-Spec OEM fog light mounting brackets. I couldnt' use them since I have the MazdaSpeed bumper and made my own. Of the the shrouds have notches in the screw holes so it could be reversed with the other fog light (kinda hard to explain, but I can post more detailed pics) in the midst of my thinking of how to mount them, but it's not noticable at all since it's on the backside. Asking $20.
![Image](http://img157.imageshack.us/img157/3084/fogbracketpr9.jpg)
94+ Dash Cupholder. Was going to modify my '92 dash to accept it, but i decided against it and had better ideas for that space. Asking $10
![Image](http://img49.imageshack.us/img49/533/cupholderde0.jpg)
K&N Filter Recharge Kit. Never opened or used. Made a new CAI instead. Worth $23. Asking $10
![Image](http://img49.imageshack.us/img49/4741/knxg2.jpg)
Mx-6 Switches. Heard that Mx-6 switches fit in Mx-3 dashs, but it seems not in the 92-93 style, not tall enough. Cruise Control, Fog Lights and Rear Defrost. Asking $20 for all
![Image](http://img154.imageshack.us/img154/5492/switcheswr9.jpg)
Horn/Cruise Control controls ring. Used to pass the signals to the wheel. Picked up as a spare for when i modified mine to accept my aftermarket wheel and hub. My modification worked first shot so I don't need it anymore. Asking $5.
![Image](http://img56.imageshack.us/img56/6532/ringyb1.jpg)
K8 Exhaust Manifolds. Have headers so I don't need these anymore. From my K8 and used on my KLZE for over 2 years. Asking $5
![Image](http://img141.imageshack.us/img141/7623/exhaustxa1.jpg)
Dash trim and vents. Holes marked in red were for USB cable for a USB hub, which was velcro'd up. Holes are not visible with cupholder in place, and harely visible if not. All's in very good condition except for the part lower dash part that the shifter trim goes on. It's mosty dirty with overspay from the previous owner. Including lower column cover which was a spare for my cruise control controls relocation mod. Asking $50 for all.
![Image](http://img218.imageshack.us/img218/2337/trimqh7.jpg)
![Image](http://img300.imageshack.us/img300/7638/column2cf6.jpg)
http://img141.imageshack.us/img141/2196/acspacerfo6.jpg
Drivers side door panel. Replaced with my JDM door panel (thanks again Taras!) Good condition, but does not come with the window controls or latch trim. Asking $20
![Image](http://img218.imageshack.us/img218/8978/paneltp5.jpg)
Horn button that came with my racing wheel. It was suppose to come with a MazdaSpeed symbol, but came with a Swiss/Red Cross symbol, which I peeled off. I have a MazdaSpeed symbol horn instead. Asking $5.
![Image](http://img291.imageshack.us/img291/6424/horn1dp4.jpg)
![Image](http://img112.imageshack.us/img112/8428/horn2zz3.jpg)
Stock shift knob. Decent condition. Original from my car, replaced this year. Asking $5
![Image](http://img291.imageshack.us/img291/1908/knobga8.jpg)
Center console cover. Shows some signs of wear, but is good condition. Does not including latch. Asking $10
![Image](http://img300.imageshack.us/img300/8043/console1el5.jpg)
![Image](http://img54.imageshack.us/img54/8470/console2eg6.jpg)
Driver Side Rear tail lights. Very good condition. From an extra set i bought for my Rx7-style tail light mod, Paid $40 for the pair, asking $10 for just this onee light.
