WTH? Why are the brakes squeling soo loud?
Juans_93_MX3
Post by Juans_93_MX3 »
The front brakes are only 4k miles old and they are squeling LOUD
What is the deal with these brakes? They usually squel when the car gets hot in 90* degree wether
I got them from AutoZone, might that be why?
Any advice on stopping the squeling?
I even checked the brakes and they still look good.
2008 Mazda 3
1993 MX3 GS
hgallegos915
Post by hgallegos915 »
oh yeah autozone.. ew LOL jk well um have you checked rotors? mine squak all the time also but i checked and they got alot of life in them.. i think they are seizing.
-hec
Juans_93_MX3
hgallegos915 wrote:oh yeah autozone.. ew LOL jk well um have you checked rotors? mine squak all the time also but i checked and they got alot of life in them.. i think they are seizing.
My rotors still look good and my brakes still have life in them but they squeal like a b1tch
2008 Mazda 3
1993 MX3 GS
ariesdude
Post by ariesdude »
Maybe some brake lube -
http://www.partsamerica.com/ProductList ... ycode=3223
I have never tried this though...
94 Mx-3 Precidia
ProspectMx3
Post by ProspectMx3 »
Sometimes its the compound of the pad. I have several times before seen where the pads no matter what you do sqeel. Most of the time its the cheap pads cause this. I think you should try a different set of pads.
Stock Sucks
Race Cars!!!
Juans_93_MX3
I guess I should have gotten brakes at Mazda not autozone
AutoZone dosent even sell the right stuff for our cars espically ENGINE MOUNTS
2008 Mazda 3
1993 MX3 GS
Si1verBullet
Post by Si1verBullet »
Some quick points, I just rebuilt my calipers.
After market pads don't come with new anti squeal shims and springs - did you replace them ?
You need follow a proper break in on the pads as the rotors are worn - have you done this ?
Are the Caliper pins in the bolts that hold the calipers on seized ? this was causing my squealing.
97' UK V6, Standard.
Custommx3
Site Administrator
Post by Custommx3 »
Heres another thing to try...
My wifes brakes squeeked really bad on her old honda and my RS.
turns out.. the brake bads had a coating on the side of the pads that werent wearing off when the pad did and was actually rolling up and always rubbing against the rotor. I took the pads off, used something to scrape that off the sides like a flat head screwdriver, and no more squeaking.
The squealing you hear could also be a wheel bearing.
