Sticking rpm gauge please helpeth thou
mazdamx3sohc
Post by mazdamx3sohc »
my rpm gauge stopped working it stays at 2 and dont move when i drive, sometimes move very very sloooooowly, most of the time it stays there, i tried hitting the dash above it. help me please. im sure i will help you someday
ryanlindenberg
Post by ryanlindenberg »
does it stay at 2 when the car is off too?
i think it's probably the guage itself that went bad.
CARDOMAIN WITH UPDATED PICS
mazdamx3sohc
dern last time i had problems cuz of my reverse glow. then it fixed itself, maybe a plug came loose.
ModMX3 - (Carmaster2005)
Post by ModMX3 - (Carmaster2005) »
Dude its most likly just sticking. mine dose that every once and a while dependeing apon the tempture. if you have reverse glow gauges there will be less clearence between the needle and the background. seems like mine tend to do this on cold days. To fix this i would just pull out the cluster gauge and try to file down the space between the needle and the bacground using a nail file. i havent got around to doing this myself yet. because i have other more urgent things to fix. but good luck with fixing it.
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
mazdamx3sohc
thank ya kindly, it dont get cold around here, its always about 90ish. mines been sticking for like 2 days now.
cjthor
Post by cjthor »
did you try punching the dash? Hey it worked for Fonzy!!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
mazdamx3sohc
it also worked for marty in back to the future when the car wouldnt start, yea i took out the reverse glows, they were sucking up too much power anyways. its still kinda act'n a foo. but meh.
